PCB design 3D models appearing on incorrect axes
alishanea
Observer Observer
alishanea
Observer
Observer
Hi All,
I've been having an issue with the 3D models for PCB components appearing incorrectly. Multiple of the same item exist in the file, only one appears to be for some reason shifted to the wrong axis. All appeared as intended last week before updating Fusion 360.
In the figure below:
Both the yellow SMD fuses are the same component. One appears correctly, the other does not. Deleting and re-adding a new element doesn't seem to fix the issue.
Likewise with a different PCB I'm working on shown in the figure below:
One of the four connectors is off-axis but I can't seem to fix it.
Here's the version info:
Is anyone else having a similar issue? Are there any known fixes for this issue?
TheCADWhisperer
@alishanea
Can you File>Export your *.f3d file or *.f3z to your local drive and then Attach it here to a Reply?
