Patterning a web feature no longer works? - Fusion
Alchemistjewelers
Observer Observer
Alchemistjewelers
Observer
Observer
In the past I have always been able to easily make tray dividers by using a web to create the first divider and then patterning the web feature. Typically the only caveat to this method is that you have to use the "adjust" compute mode in the pattern. I just opened up a previously saved model that I wanted to adjust the divider spacing of and it seems like I can no longer pattern the web feature in it. I then created a new, simple test model and am having the same issue?  Am i going crazy or is this broken?   I am currently running the free individual license, if that matters.
This post has been edited due to: @heather_tracy added the product to the title to help more community members find this topic.
TheCADWhisperer
@Alchemistjewelers
Did you previously pattern the sketch or the feature?
Alchemistjewelers
Observer
Observer
Ive attached my original file where i discovered the problem.
in the timeline, R-Pattern1 and R-Pattern2 are the 2 patterns that no longer work.  I have these set up with parameters colum_divisions and row_divisions.
Thanks!
arjun_pillaiZCXQN
Hi @Alchemistjewelers ,
Thank you for taking the time to report this issue. I was able to reproduce the behavior on my end, and I’ve raised a ticket (FUS-226058) to the team for further investigation.
If my answer helped, please 'Accept Solution'
Arjun Pillai
Quality Assurance
Autodesk, Inc.
