Pattern on Path not Working "Object is too complex"
agentnoah
Observer Observer
Message 1 of 9
agentnoah
Observer
Observer
I am trying to repeat a simple pattern, but Fusion won't copy one of the face sets. If I do it individually, it claims it is too complex to compute and suggests I select less faces. It's literally only two triangles, I don't understand how it's too complex. Pictures below, I have all the appropriate faces selected
Objects I'm trying to duplicate
Preview showing that it will work as intended
Bottom object will not copy via pattern
Error if I try to just copy the bottom object
Replies (8)
Message 2 of 9
g-andresen
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
Message 3 of 9
agentnoah
Observer
Observer
Here it is. It is the "Angles" ring, in case the other components are there too
Message 4 of 9
jhackney1972
I did not see your model.
John Hackney, Retired
Message 5 of 9
jhackney1972
Why not use a Circular Pattern instead of Pattern on a Path.  You can use full or partial circular pattern as needed.  Model is attached of a partial pattern.
Message 6 of 9
jeff_strater
It works as a feature pattern, with the compute type set to "Adjust"
With pattern of any kind, the rule is:  try all the different types.  One of them will probably work.
If I were to speculate, the "too complex" error is because of this non-manifold edge:
That can't be manufactured.  But, that is just a guess....
edited model attached.
Jeff Strater
Engineering Director
Message 7 of 9
jeff_strater
and yes, @jhackney1972 is right - circular pattern is better than pattern on path in this case.  However, it has the same problem.  Circular, also, does work for Feature/Adjust..
Jeff Strater
Message 8 of 9
agentnoah
Observer
Observer
Thanks, this fixed it. Idk if that point will work with my 3D printer or not, but the point is to find out
Message 9 of 9
g-andresen
Pattern on path is difficult or even impossible to handle if the path is a closed profile.
Therefore, I agree with the  recommendation by @jhackney1972to create a circular pattern.
günther
