Parts4Cad Support?
Parts4Cad Support?
HughesTooling
Consultant Consultant
Parts4Cad Support?
HughesTooling
Who does support for the parts4cad plug-in? I've found that parts with a point in the part number don't get assigned the correct part number in Fusion. So a 6.5mm ejector pin from DMS for example will be given the name _AH6, it should be _AH6.5x160. If I select a 6mm pin it imports with the correct name, _AH6x160. I've tested with parts from other suppliers and get the same problem, part numbers are truncated at full stops\decimal points.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
paul.clauss
Hi @HughesTooling
Thanks for posting! I was able to reproduce this issue and have logged it as FUS-33822. While I am not sure if this is an error on our end or from Parts4Cad, we will be looking into it. As always, we appreciate you bringing this to our attention.
Paul Clauss
Product Support Specialist
