Parts List
Parts List
alucero49
Parts List
alucero49
Hi,  I am try to create a parts list, however, the balloons don't seem to match the table.  Any help would be appreciated.  Tried to take a screenshot through the app and it crashed.
Using Fusion 360 Mac.  Downloaded from Autodesk website.
innovatenate
Autodesk Support
Autodesk Support
Welcome to the Fusion Community! Sorry to hear about the issues with the balloons.
Could you share the design with us? If you would prefer to keep it private, please feel free to private message me a share link.
https://knowledge.autodesk.com/support/a360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-sh...
I look forward to your response.
Kind regards,
Nathan Chandler
Principal Specialist
alucero49
I sent a private message with the public link.
innovatenate
Autodesk Support
Autodesk Support
Thanks for sharing the data with me. I can see the issue. For example, in Section A view, the balloon with number 1 is does not match what is in the parts list (sorry to be vague, I'm trying to keep details of the design private).
I notice that if I edit the balloon and reassociate it, that balloon ID's  update correctly.
I'm aware of one known workflow that causes similar symptoms, this issue is actively under investigation. When promoting or demoting components through the browser structure (moving a component from being a sub-component up a level or visa versa), there is an open ticket around this. Does this sound like the right workflow to reproduce the issue to you?
In note, any insight you may be able to share on how to reproduce this issue will be very helpful. Thank you for reporting this.
Nathan Chandler
alucero49
I tried to re-assosiated and the correct BOM number is shown but 9 becomes 19 and 10 becomes 20.  So I try renumbering which seems to work.  However, the BOM doesn't update correctly.  I end up with multiple same numbers.  Think I found the problem.  I seem to have a phantom Parts List.  I had two so I tried deleting both.  I was only able to delete one.
Edited: Added picture
innovatenate
Autodesk Support
Autodesk Support
I wanted to let you know that I'm still investigating this issue and will circle back just as soon as I have further information.
Thank you,
Nathan Chandler
