PART IN PLACE
PART IN PLACE
tavaral21HHRNF
Observer Observer
PART IN PLACE
tavaral21HHRNF
Observer
Observer
HI ALL!
I was wondering if anyone knew how to create a "part in place" from an assembly and making it a separate file to generate a 2D drawing afterward? I know I can create a new component within an assembly but Fusion would not let me make this part a single separate part to mod off the assembly. Please advise.
Thank you so much in advance for your help.
V/R.
davebYYPCU
Not my normal workflow, so may not be correct, try
If you have Rule #1 component structure, select the component, right click, Save As, (newname.f3d)
If you have external references to that part of the design, (not Rule #1 structure) may or may not work.
Might help....
g-andresen
1. You can even create a 2D derivation from the isolated part without creating a new file.
2. Use save copy as to create a separate file from the selected part.
günther
tavaral21HHRNF
Observer
Observer
This works good! Thank you so much. My main platform is solid edge by siemens so I am adventuring more in the 360world which, so far I love.
tavaral21HHRNF
Observer
Observer
Sweet! thank you! I tried this too and worked fine. Thank you for your insight!
