New to Fusion, this is one of my first designs.
I have create 3 simply cabinetry jigs that use parametric values more specifically 1 parameter of type TEXT to assign automatically assign the text to the text box based on the parameter.
For some reason 2 of the files work correctly in that I can simply change the parameter and the text auto-updates but this 3rd file always reverts to the value of the parameter in both locations where text exists.
Works as expected: T Parameterized.f3d
Text box not working correctly and converting to value: Plus Parameterized.f3d
I am sure that I am the problem here but can't for the life of me understand why it work in one file but not the other.
To make matters worse, I can correct the problem, save the file and it will revert back to the text value as opposed to the parameter the next time I open the file.
