Parametric size changes move location of parts
sleitman
sleitman
I am trying to make an acrylic box whose dimensions can be changed using changes in parameters.  I have tried to change the size of sketch elements, bodies, and components.  The size changes just fine but the location of the parts moves around so instead of a box, I have 5 random bodies in space.  I have tried to make all of the items a rigid group, I have tried various joints, grounds and pins.
I have done a great amount of searching for answers to my problem online.  I have watched multiple videos.  I feel that I must be missing some fundamental concept in Fusion and would love a pointer for what I should look up to sort out my obvious misunderstanding.
Thank you in advance for any help,
Sasha
TheCADWhisperer
There are two different techniques that you can use to achieve reliable and predictable behavior.
sleitman
Thanks, I am attaching a simplified file so that I can learn from your suggestions.
Thank you so much for your help.
Sasha
sleitman
It appears that I accidentally posted this question twice.  The answer can be found here:
https://forums.autodesk.com/t5/fusion-360-support/changes-in-parameter-values-move-componenent-locat...
Solution:
The part that I was missing was constraints.  After watching that forum answer video, I found this tutorial which was also helpful:
https://help.autodesk.com/view/fusion360/ENU/courses/AP-SKETCH-BASICS
