Parametric Hypotenuse of Triangle
dcpanzone
dcpanzone
Hi, having some problems with the syntax of the expression in parameters to drive a hypotenuse value.
sqrt((d80^) + (d80^))
I hope I'm close with this but not sure. d80 is also a driven dimension, but it should be able to have a down stream effect correct?
Any help is appreciated!
Thanks!
dcpanzone
screen shot for reference
jeff_strater
first, driven dimensions cannot be used in an equation in Fusion currently.  Second, you have to make the units correct.  sqrt() only works on "unitless" numbers.  So, you have to remove the units from any distance dimensions, something line "(x/1 mm)" will return a unitless version of a distance "x".  Then, to square it, you use "^2".  So the whole equation would look like "( sqrt(( x / 1 mm ) ^ 2 + ( y / 1 mm ) ^ 2) ) * 1 mm"
Jeff Strater
Engineering Director
