parameters - can't take cube root of parameter with inch units
turningGCH43
turningGCH43
I'm stumped by this one, probably a simple solution.
I have parameters:
name          units     expression            value
diameter      in        27                    27
dia_no_units            27                    27
D_cube_root   in        diameter ^ (1/3)      <<<< not allowed (stays red)
D_cube_root             diameter ^ (1/3)      <<<< not allowed
D_cube_root   in        dia_no_units ^ (1/3)  3   <<<< works
I can't get cube root to work on values that have units. Also tried power function.
Is there a way to de-unitize a parameter so that I can just use the math function?
jeff_strater
units cancellation (divide by 1mm to cancel out the units) seems to work
Jeff Strater
Engineering Director
turningGCH43
Thanks.
I knew there had to be a way to cancel units. Dividing by units is very unintuitive. I was aware of the multiply by units.
Both seem a little hack-y to me.
Additionally, I did not find this documented anywhere. No mention of it with all the parameter & function documentation that I could find. Maybe I missed it.
g-andresen
During my time at school, I learned to set up unit equations in parallel with numerical equations.*
This was a method to reduce errors in the calculations.
It still helps me today when developing equations in Fusion.
günther
* The slide rule and later the pocket calculator knew no units.
turningGCH43
Yeah, I totally get and agree that having the units carried along is a good idea and useful as a cross check in a lot of situations. The problem is that it won't let you take the cube root of a linear unit parameter. I needed this for a screw tolerance calc from spec formulas.
now that I know the /unit trick, it's not a big deal.
