Parallel Tool Path Problems in Latest "Manufacturing" CAM version.
schuran
schuran
I have two identical chamfers that I'm trying to create using the 3D parallel tool path.  I've done this hundreds of times without a problem and now with the latest program update I'm getting this.
The path on the right is correct (shading makes the chamfers look different but they are not) while the path on the left is incorrect.  These are identical tool paths and identical boundary selections - copy and pasted with just changed the boundary.
I've also noticed a number of strange instances where I go from "Manufacturing" to the model space and without changing anything I go back to Manufacturing and I've lost a number of references.  This latest update appears to be very unstable.  Any way I can go back to when we had CAM instead of the arts and crafts version of Manufacturing....
masa.minohara
Hi @schuran ,
Thank you for posting in the forum! You can disable Manufacture Workspace in the Preferences menu and access CAM workspace again.
Could you share a public link to the design with me so I can take a closer look at the issue?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
