Pan and Orbit stopped working with mouse wheel
jacksmailer
Message 1 of 17
jacksmailer
Not sure what I did wrong, but unexpectedly the mouse wheel only works for zooming.
I tried all the options in Preferences/Pan, Zoom, Orbits shortcuts to no avail.
Any ideas?
Accepted solutions (3)
Replies (16)
Message 2 of 17
I_Forge_KC
Have you checked to see if the middle mouse button works in other applications? There seems to be a big rash of people's middle mouse button dying here the last little bit.
A simple test would be to go to a website, middle click, and see if the scroll widget pops up. If it does, your mouse button is working. If it doesn't... well... try another mouse just to see.
K. Cornett
Generative Design Consultant / Trainer
Message 3 of 17
If anyone else is Plagued with this problem, they know how frustrating it can be. I found the SOULTION.... but first, my problem. It all started Monday, when I logged into fusion to do some doodling. I noticed that whenever I clicked to orbit a little plus (zoom) symbol appeared. It turned out it was just a "setpoint" setting, that was set "center botton 3" zoom instead of "center button".
1. use a local search to search setpoint.
2. change settings
3. enjoy
Message 4 of 17
2. change settings
3. enjoy
I have a multi-button mouse, and all of sudden my click wheel is no longer serving its assigned role, but another button is. Pcollery, are you using a PC or Mac? I'm on a Mac, and I had no luck with a return of "setpoint". I'm not sure I know what you mean by a "local" search; local to the OS? Fusion 360?
Message 5 of 17
What he is referring to is: 1. Click on the orbit icon There will be a "plus" or cross-hair in the center of your screen. 2. Move your mouse and click on the cross-hair (that plus ;-) That's it. Press escape to exit the orbit mode and all works fine. At least for me it did. Do find it strange this sudden change in behaviour somehow happened during normal operation and I do not know how... Anyway hope this helps! Cheers! Hans
Message 6 of 17
piotrowski12
Your advice is not working. It's terribly irritating. The mouse is OK. How can Autodesk allow such an annoying error? I can not work!
Message 7 of 17
Hi piotrowski12
That is too bad my advice did not work for you.
It did work for me, I had the same issue with my Logitech Trackman (which is actually an ordinary mouse).
Since my mouse does not require any specific drivers I figured your issue is the same as mine.
In any case I would then advice to:
- test Fusion 360 with another mouse device (make absolutely sure it is not a mouse and/or -driver)
- uninstall Fusion 360
- check your mouse driver software, if necessary reinstall and test your mouse functionality
- install Fusion 360 again
Again, hope this helps!
Cheers!
Hans
Message 8 of 17
Phil.E
@Anonymous Thanks for your great community support.
@piotrowski12 Don't uninstall Fusion just yet. Let's try some other things before making that leap.
First, restart your computer. The problem is likely a driver issue.
If it were a general Fusion problem there would be thousands of people complaining about it. So the logical conclusion is it's an issue local to your machine. This means it's the physical mouse itself, or the drivers, or your machine is in a state where the mouse drivers aren't working correctly. So you should eliminate your local conditions first before reinstalling Fusion. Fusion simply reacts to the input your machine is giving it.
What model of mouse are you using? Have you tried another mouse? Are you on Win or Mac?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 17
patrick.hutton
Actually, what is being referred to here is the Logitech application called "Setpoint" and by local search it means windows start button search bar, type setpoint to open up the Logitech mouse settings app. Actually for me this then crashes but after it does the mouse behaviour was as expected!
Message 10 of 17
Phil.E
Thanks for posting. I've heard good feedback about the more recent Logitech drivers, but I don't have such a mouse to test it myself. Definitely if you have a Logitech mouse, update all the drivers and software to the latest version. Let us know your experience.
Hardware driver behavior is not entirely within control of Fusion 360, but we can always try to make it work better if you find issues.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 11 of 17
scottS4EDN
Installing Setpoint then workign on the settings via their taskbar clock area app (which installed with setpoint) fixed it for me.  The middle button was set to "middle button" when I opened the app, but when I Clicked "restore defaults" it changed to "scroll".  I then manually set #3 to to "middle button" and that fixed mine.
Message 12 of 17
thomas.muellner
Community Visitor
Community Visitor
Having the same issue, but I don't have a Logitech mouse. Everything worked fine a few days ago. Now it's very frustrating.
Message 13 of 17
Phil.E
Thanks for reporting.
Have you tried any of these published solutions?
Solutions found:
  • Windows: Enable scrolling in inactive window (windows mouse settings)
  • Mac: Uninstall Native Trackpad
  • Fusion 360: Enable camera pivot in Fusion 360 preferences.
  • Logitech: Disable Mouse Wheel "tilt" (L/R tilting for side to side scrolling)
Reference post:
https://forums.autodesk.com/t5/fusion-360-support/mouse-scrolling-not-zooming-in-out-after-april-upd...
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 14 of 17
jasshrie
Ran into this issue today and finally closed all apps and restarted the system (Win10) and it began working again. Sometimes the old-school fix of a restart is all it needs 😄
Message 15 of 17
mjm.productions
Had same problem after I removed (cleaned) accumulated dirt from wheel.
Because of that I probably dislocated the pin pressing the switch inside the mouse when clicking the wheel button.
Opened the mouse, verified the switch functionality from the wheel, held "Shift key" down in F360 and the orbiting function worked again.
Carefully reassembled and everything is fine again.
BTW: It's an ordinary USB Logitech wireless mouse M185 type.
Hope this helps anyone.
Message 16 of 17
frankrombaut
For Microsoft mouse users with the same problem see printscreen that fixed this for me.
Message 17 of 17
josesauraURBW2
Observer
Observer
    Worked for me.
    I have a Logitech M720 Mouse. I used the app Logi Options+ to disable the L/R tilting. They can also be set to "Middle Button" instead of the default that is scroll left/right.
    Thank you!
