Paint applied to surface of transparent material does not show through back.
Here I have some nested cylinders with a semi circle groove cut into the OD of each layer. I have applied a paint appearance to the "trough" of each groove however when the part is given a physical material of glass you cannot see the paint color through the rear of the glass.
To put it simply, if I "paint" a sheet of glass on one side I cannot see the painted surface through the opposite side, the color disappears.
In the first image notice the appearance of the yellow/red grooves at 12 o'clock vs the blue/green grooves at 6 o'clock. In the final image you can see how this is causing a problem for me with my render. I want to see the painted groove along its entire path.
