Outline curves in template drawings not thickened
moriarty.chch
moriarty.chch
Normally outline curves in ISO drawings appear thickened in PDF output
This good behavior turns bad when using templates - outlines become thin
Turns out that inserting images (INSERT> Image   *.jpg etc) into templates is the culprit - all image formats cause the rendering fault.
Worse still - deleting the image from the template doesnt fix it - you have to use a template revision prior to the image being addded. Inserting the image into a drawing doesnt produce the fault.
Thickened outlines was one of the few nice features of drawings in F360 - hopefully it can be fixed
2.0.6670  Win10
g-andresen
does that have any influence?
günther
