Origin has suffered the ongoing attack of the feint and is difficult to see.
rhetths
rhetths
The Origin has suffered the ongoing attack of the feint and is difficult to see.
wmhazzard
Open your active component and turn on visibility of the components origin or activate the top level.
sutherland-
Dear @rhetths
Please try to select the (unsaved) component and then Activate it by pressing the little circle.
That will fix the issue.
Best,
Kritzz
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
rhetths
So if i have a component activated it makes the global origin feint.  Is that a good thing?
What if i want to see if the global and component origins are in the same or different places, or otherwise how they are in relation to each other, would that mean i should have the component inactivated?
What if i am trying to align the component to the global origin, in that case should i also have the component inactivated?
jhackney1972
If you do not want the top level origin, or for that matter, any component to not fade when you activate a component remove the indicated check mark in your Preferences.
John Hackney, Retired
rhetths
Thanks, i will ponder that.,
