Operation displaying toolpath in workspace but unable to simulate or post
lucasD7TLR
Message 1 of 8
lucasD7TLR
I have encountered a problem yesterday that has persisted until this morning where after generating some operations the toolpath would be displayed in the workspace but attempting to simulate the toolpath results in an empty toolpath warning. Attempting to post the operations in question also results in an empty program. Furthermore this problem only affects certain operations within the file.Capture.PNGCapture1.PNG
Replies (7)
Message 2 of 8
seth.madore
Is there a chance that those are contained in a Pattern further up in the Browser?
Can you share your file, even if only privately?
File > Export > save to local folder, return to thread and attach the .f3d file in your reply, or email it directly to me: seth dot madore at autodesk dot com
Seth Madore
Message 3 of 8
lucasD7TLR
These operations are contained within a pattern but each pattern is single order within the setup. It seems that the patterns function properly if two or more instances of the operations are generated but not if only a single instance is generated (eg. #of instances=2 with "keep original" unchecked)
Message 4 of 8
seth.madore
Yes, I suspected as much. This is a known bug that slipped into the last update. We are working towards a fix and hope to have it released ASAP.
Seth Madore
Message 5 of 8
rpalf
same problem, siulation runs at super hero hyper speed......
Message 6 of 8
seth.madore
@rpalf what you are describing is not the same as what this thread is about. Where is the slider set to in Simulation?
Seth Madore
Message 7 of 8
rpalf
Hi
it makes no difference where I place the slider.
Ray
Message 8 of 8
seth.madore
What version of Fusion are you on, as we fixed this issue a couple of updates ago
Seth Madore
