operating system problem
mariano_fillol
mariano_fillol
Community Visitor
Community Visitor
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Administrator\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001DF6A865190> #
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\ADMINI~1\AppData\Local\Temp\7zS70A0.tmp\resources\buildinfo.json
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240418130205
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\ADMINI~1\AppData\Local\Temp\7zS70A0.tmp\resources
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\ADMINI~1\AppData\Local\Temp\7zS70A0.tmp\certs.pem
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000001DF6A855F80>, operation=<function multiple_operate at 0x000001DF69F35EE0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-07-07 18:42:22,895 - MainProcess(6608) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-07-07 18:42:23,129 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-07-07 18:42:23,192 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\Administrator\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.registry - INFO :: Failed to query database schema, initializing.
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm created successfully
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\Administrator\AppData\Local\Autodesk\check_perm removed successfully
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\Administrator\AppData\Local\Autodesk
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-07-07 18:42:23,957 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 18:42:23,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:23,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:23,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:23,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-07-07 18:42:23,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-07-07 18:42:24,051 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.87.43.29
2024-07-07 18:42:24,082 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-07-07 18:42:24,113 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjQzLjI5
2024-07-07 18:42:24,113 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4wLjM4
2024-07-07 18:42:24,113 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 18:42:24,113 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-07-07 18:42:24,223 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001DF6A890C10>
2024-07-07 18:42:24,223 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 18:42:24,285 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 18:42:24,285 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 18:42:24,285 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 18:42:24,285 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 18:42:24,301 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:24,301 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:24,301 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:24,395 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-07-07 18:42:24,395 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-07-07 18:42:24,395 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-07-07 18:42:24,395 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 18:42:24,441 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:24,441 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:24,441 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:24,566 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001DF6A8A7850>
2024-07-07 18:42:24,566 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 18:42:24,582 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 18:42:24,582 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 18:42:24,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:24,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:24,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:24,801 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001DF6A8A7710>
2024-07-07 18:42:24,801 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-07-07 18:42:24,801 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-07-07 18:42:24,801 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 18:42:24,832 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:24,832 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:24,832 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:24,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001DF6A8A75D0>
2024-07-07 18:42:24,988 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 18:42:25,020 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 18:42:25,020 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 18:42:25,020 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 18:42:25,020 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 18:42:25,035 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:25,035 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:25,035 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:25,457 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-07-07 18:42:25,457 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-07-07 18:42:25,457 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-07-07 18:42:25,457 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 18:42:25,457 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 18:42:25,488 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 18:42:25,488 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 18:42:25,488 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 18:42:25,613 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 2838caf6-bdd6-4ae6-bc2c-07b88e06f35d
2024-07-07 18:42:25,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.19440 for app 73e72ada57b7480280f7a6f4a289729f
2024-07-07 18:42:25,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-07-07 18:42:25,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-07-07 18:42:25,629 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-07-07 18:42:25,676 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Current OS version [10, 0, 17134] is unsupported.
2024-07-07 18:42:25,723 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-07-07 18:42:25,723 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjQzLjI5
2024-07-07 18:42:25,723 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4wLjM4
2024-07-07 18:42:25,848 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgVW5Lbm93bg0sIEFkZHJlc3M6ICAyODAwOjgxMDoxMDA6MjoxOTA6NTU6NjA6MTI5DQ==
2024-07-07 18:42:25,848 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 18:42:25,848 - MainProcess(6608) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\src\adsk\dls\streamer\process\process.py", line 1190, in execute
File "R:\src\adsk\dls\streamer\process\deploy_process.py", line 95, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 1120, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 924, in _config_app
File "R:\src\adsk\dls\streamer\process\process.py", line 415, in _executetasks
File "R:\src\adsk\dls\streamer\platform_base.py", line 484, in check_required_version
adsk.dls.streamer.exceptions.UnsupportedOSVersion: The current operating system is unsupported, this application requires Windows 10 Build 1803
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Administrator\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002AA846496D0> #
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\ADMINI~1\AppData\Local\Temp\7zS6292.tmp\resources\buildinfo.json
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240418130205
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\ADMINI~1\AppData\Local\Temp\7zS6292.tmp\resources
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\ADMINI~1\AppData\Local\Temp\7zS6292.tmp\certs.pem
2024-07-07 23:05:17,951 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000002AA84635F80>, operation=<function multiple_operate at 0x000002AA83D15EE0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-07-07 23:05:17,966 - MainProcess(4616) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-07-07 23:05:18,529 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-07-07 23:05:18,591 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\Administrator\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm created successfully
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\Administrator\AppData\Local\Autodesk\check_perm removed successfully
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\Administrator\AppData\Local\Autodesk
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-07-07 23:05:18,638 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - ERROR :: Failed to log network information because of exception [Errno 11001] getaddrinfo failed
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.network_checker - WARNING :: Failed to get network connection information [Errno 11001] getaddrinfo failed.
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host autodesk.com is not accessible
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 23:05:18,685 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-07-07 23:05:18,701 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Exception occured: <urlopen error [Errno 11001] getaddrinfo failed>
2024-07-07 23:05:18,701 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-07-07 23:05:18,701 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-07-07 23:05:18,701 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:05:18,732 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:05:18,732 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:05:18,732 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:05:18,747 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Exception occured: <urlopen error [Errno 11001] getaddrinfo failed>
2024-07-07 23:05:18,747 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- FAILURE
2024-07-07 23:05:18,747 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-07-07 23:05:18,747 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:05:18,794 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:05:18,794 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:05:18,794 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:05:18,794 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Failed to get apps.
2024-07-07 23:05:18,794 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-07-07 23:05:18,794 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {'CheckNetworkConnectivity': '{"description":"VW5hYmxlIHRvIGNvbm5lY3QgdG8gTmV0d29yay4gUGxlYXNlIGNoZWNrIHRoZSBjb25uZWN0aW9uLg==","url":"aHR0cHM6Ly9rbm93bGVkZ2UuYXV0b2Rlc2suY29tL2FydGljbGUvUHJlY2hlY2stTmV0d29yay1Db25uZWN0aXZpdHktaXNzdWUtRnVzaW9uLTM2MA=="}'}
2024-07-07 23:05:18,794 - MainProcess(4616) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.analytics - INFO :: Sending analytics for command "Deploy.NetworkConnectivityError" args: [None, None]
2024-07-07 23:05:47,439 - MainProcess(4616) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.analytics - WARNING :: Failed to send data to ADP because of exception 'NoneType' object has no attribute 'split', command "Deploy.NetworkConnectivityError" args: [None, None]
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm created successfully
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\Administrator\AppData\Local\Autodesk\check_perm removed successfully
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\Administrator\AppData\Local\Autodesk
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-07-07 23:05:47,439 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Exception occured: <urlopen error [Errno 11001] getaddrinfo failed>
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-07-07 23:05:47,501 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Exception occured: <urlopen error [Errno 11001] getaddrinfo failed>
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- FAILURE
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-07-07 23:05:47,579 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:05:47,657 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:05:47,657 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:05:47,657 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:05:47,673 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Failed to get apps.
2024-07-07 23:05:47,673 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-07-07 23:05:47,673 - MainProcess(4616) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {'CheckNetworkConnectivity': '{"description":"VW5hYmxlIHRvIGNvbm5lY3QgdG8gTmV0d29yay4gUGxlYXNlIGNoZWNrIHRoZSBjb25uZWN0aW9uLg==","url":"aHR0cHM6Ly9rbm93bGVkZ2UuYXV0b2Rlc2suY29tL2FydGljbGUvUHJlY2hlY2stTmV0d29yay1Db25uZWN0aXZpdHktaXNzdWUtRnVzaW9uLTM2MA=="}'}
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Administrator\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002741AF596D0> #
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\ADMINI~1\AppData\Local\Temp\7zSBCCE.tmp\resources\buildinfo.json
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240418130205
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\ADMINI~1\AppData\Local\Temp\7zSBCCE.tmp\resources
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\ADMINI~1\AppData\Local\Temp\7zSBCCE.tmp\certs.pem
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000002741AF45F80>, operation=<function multiple_operate at 0x000002741A625EE0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-07-07 23:07:52,214 - MainProcess(4464) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-07-07 23:07:52,542 - MainProcess(4464) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-07-07 23:07:52,605 - MainProcess(4464) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-07-07 23:07:53,402 - MainProcess(4464) - InstallDriver - adsk.dls.streamer.registry - INFO :: Close registry connection.
2024-07-07 23:07:53,402 - MainProcess(4464) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: The registry is locked at this moment. Please refer to detailed information: "This process failed because of another installer deploy in process"
2024-07-07 23:08:47,581 - MainProcess(4464) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-07-07 23:08:47,581 - MainProcess(4464) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Administrator\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000200BAEE96D0> #
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\ADMINI~1\AppData\Local\Temp\7zSE10A.tmp\resources\buildinfo.json
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240418130205
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\ADMINI~1\AppData\Local\Temp\7zSE10A.tmp\resources
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\ADMINI~1\AppData\Local\Temp\7zSE10A.tmp\certs.pem
2024-07-07 23:09:07,080 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x00000200BAED5F80>, operation=<function multiple_operate at 0x00000200BA5B5EE0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-07-07 23:09:07,095 - MainProcess(3576) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-07-07 23:09:07,392 - MainProcess(3576) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-07-07 23:09:07,470 - MainProcess(3576) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-07-07 23:09:08,283 - MainProcess(3576) - InstallDriver - adsk.dls.streamer.registry - INFO :: Close registry connection.
2024-07-07 23:09:08,283 - MainProcess(3576) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: The registry is locked at this moment. Please refer to detailed information: "This process failed because of another installer deploy in process"
2024-07-07 23:09:34,688 - MainProcess(3576) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-07-07 23:09:34,688 - MainProcess(3576) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Administrator\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000028249BC96D0> #
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\ADMINI~1\AppData\Local\Temp\7zS5FFE.tmp\resources\buildinfo.json
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240418130205
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\ADMINI~1\AppData\Local\Temp\7zS5FFE.tmp\resources
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\ADMINI~1\AppData\Local\Temp\7zS5FFE.tmp\certs.pem
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x0000028249BB5F80>, operation=<function multiple_operate at 0x0000028249295EE0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-07-07 23:09:38,984 - MainProcess(2352) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-07-07 23:09:39,000 - MainProcess(2352) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-07-07 23:09:39,000 - MainProcess(2352) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-07-07 23:09:39,250 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-07-07 23:09:39,297 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\Administrator\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm created successfully
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\Administrator\AppData\Local\Autodesk\check_perm removed successfully
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\Administrator\AppData\Local\Autodesk
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-07-07 23:09:40,047 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:09:40,078 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,078 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,078 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,078 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-07-07 23:09:40,078 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-07-07 23:09:40,094 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.87.43.29
2024-07-07 23:09:40,109 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-07-07 23:09:40,125 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjQzLjI5
2024-07-07 23:09:40,125 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4wLjM4
2024-07-07 23:09:40,125 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 23:09:40,125 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-07-07 23:09:40,203 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000028249BF2BD0>
2024-07-07 23:09:40,203 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 23:09:40,218 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 23:09:40,218 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 23:09:40,218 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 23:09:40,218 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 23:09:40,234 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,234 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,234 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,312 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-07-07 23:09:40,312 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-07-07 23:09:40,312 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-07-07 23:09:40,312 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:09:40,343 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,343 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,343 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,422 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000028249C07510>
2024-07-07 23:09:40,422 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 23:09:40,437 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 23:09:40,437 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 23:09:40,468 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,468 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,468 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,531 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000028249C073D0>
2024-07-07 23:09:40,531 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-07-07 23:09:40,531 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-07-07 23:09:40,531 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:09:40,578 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,578 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,578 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,640 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000028249C07290>
2024-07-07 23:09:40,640 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 23:09:40,656 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 23:09:40,656 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 23:09:40,656 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 23:09:40,656 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 23:09:40,687 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,687 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,687 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,765 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-07-07 23:09:40,765 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-07-07 23:09:40,765 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-07-07 23:09:40,765 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 23:09:40,765 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 23:09:40,797 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:09:40,797 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:09:40,797 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:09:40,875 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 4b88f004-dba2-4940-80f5-4711907c1dfd
2024-07-07 23:09:40,875 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.19440 for app 73e72ada57b7480280f7a6f4a289729f
2024-07-07 23:09:40,875 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-07-07 23:09:40,875 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-07-07 23:09:40,875 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-07-07 23:09:40,937 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Current OS version [10, 0, 17134] is unsupported.
2024-07-07 23:09:40,953 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-07-07 23:09:40,953 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjQzLjI5
2024-07-07 23:09:40,953 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4wLjM4
2024-07-07 23:09:41,093 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgVW5Lbm93bg0sIEFkZHJlc3M6ICAyODAwOjgxMDoxMDA6MjoxOTA6NTU6NjA6MTI5DQ==
2024-07-07 23:09:41,093 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 23:09:41,093 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
2024-07-07 23:10:39,980 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-07-07 23:10:39,980 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Deploy The current operating system is unsupported, this application requires Windows 10 Build 1803
2024-07-07 23:10:41,219 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2024-07-07 23:10:41,219 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-07-07 23:10:41,219 - MainProcess(2352) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Administrator\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001B5F78E96D0> #
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\ADMINI~1\AppData\Local\Temp\7zS6F4B.tmp\resources\buildinfo.json
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240418130205
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\ADMINI~1\AppData\Local\Temp\7zS6F4B.tmp\resources
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\ADMINI~1\AppData\Local\Temp\7zS6F4B.tmp\certs.pem
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000001B5F78D5F80>, operation=<function multiple_operate at 0x000001B5F6FB5EE0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-07-07 23:10:48,453 - MainProcess(2304) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-07-07 23:10:48,703 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-07-07 23:10:48,766 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\Administrator\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm created successfully
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\Administrator\AppData\Local\Autodesk\check_perm
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\Administrator\AppData\Local\Autodesk\check_perm removed successfully
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\Administrator\AppData\Local\Autodesk
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-07-07 23:10:49,812 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:10:49,859 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:49,859 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:49,859 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:49,859 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-07-07 23:10:49,859 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-07-07 23:10:49,906 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.87.43.29
2024-07-07 23:10:49,922 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-07-07 23:10:49,953 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjQzLjI5
2024-07-07 23:10:49,953 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4wLjM4
2024-07-07 23:10:49,953 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 23:10:49,953 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-07-07 23:10:50,016 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001B5F7912BD0>
2024-07-07 23:10:50,016 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 23:10:50,047 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 23:10:50,047 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 23:10:50,047 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 23:10:50,047 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 23:10:50,062 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:50,062 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:50,062 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:50,125 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-07-07 23:10:50,125 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-07-07 23:10:50,125 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-07-07 23:10:50,125 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:10:50,172 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:50,172 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:50,172 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:50,234 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001B5F7927510>
2024-07-07 23:10:50,234 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 23:10:50,266 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 23:10:50,266 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 23:10:50,281 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:50,281 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:50,281 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:50,344 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001B5F79273D0>
2024-07-07 23:10:50,344 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-07-07 23:10:50,344 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-07-07 23:10:50,344 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-07-07 23:10:50,375 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:50,375 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:50,375 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:50,437 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001B5F7927290>
2024-07-07 23:10:50,437 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-07-07 23:10:50,484 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-07-07 23:10:50,484 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.87.43.29
2024-07-07 23:10:50,484 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 23:10:50,484 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 23:10:50,500 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:50,500 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:50,500 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:50,578 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-07-07 23:10:50,578 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-07-07 23:10:50,578 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-07-07 23:10:50,578 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-07-07 23:10:50,578 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-07-07 23:10:50,609 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-07-07 23:10:50,609 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-07-07 23:10:50,609 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-07-07 23:10:50,672 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is bdc9ecf9-e13e-477e-a35a-da074cd2b92d
2024-07-07 23:10:50,672 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.19440 for app 73e72ada57b7480280f7a6f4a289729f
2024-07-07 23:10:50,672 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-07-07 23:10:50,672 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-07-07 23:10:50,672 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-07-07 23:10:50,734 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Current OS version [10, 0, 17134] is unsupported.
2024-07-07 23:10:50,750 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-07-07 23:10:50,750 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg3LjQzLjI5
2024-07-07 23:10:50,750 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4wLjM4
2024-07-07 23:10:51,031 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgVW5Lbm93bg0sIEFkZHJlc3M6ICAyODAwOjgxMDoxMDA6MjoxOTA6NTU6NjA6MTI5DQ==
2024-07-07 23:10:51,031 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-07-07 23:10:51,031 - MainProcess(2304) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\src\adsk\dls\streamer\process\process.py", line 1190, in execute
File "R:\src\adsk\dls\streamer\process\deploy_process.py", line 95, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 1120, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 924, in _config_app
File "R:\src\adsk\dls\streamer\process\process.py", line 415, in _executetasks
File "R:\src\adsk\dls\streamer\platform_base.py", line 484, in check_required_version
adsk.dls.streamer.exceptions.UnsupportedOSVersion: The current operating system is unsupported, this application requires Windows 10 Build 1803
CGBenner
@mariano_fillol
Hello and welcome.  Can we assume that this is a problem with installing Fusion?
Chris Benner
Industry Community Manager – Design & Manufacturing
jhackney1972
Next time you post a log file, simply attach the file instead of pasting it directly to the Forum. Since your Windows operating system is not up to date, according to the Log report, you need to update it.  This is normally an automatic process but if you need to do it manually, you can go to this webpage which outlines the process.  If your system is not capable of updating, then you will not be able to install Fusion as older versions are not available.
If you need, capture a screen shot of your current Windows installation and post it to help with troubleshooting such as the one below.
John Hackney, Retired
CGBenner
@mariano_fillol Hello, do you still need help with this question?
Chris Benner
