Open a drawing designed in autocad LT with Fusion 360
Hello. Today I'm working with autoCAD LT but I want to migrate to Fusion 360 to model in 3D. I want to check if with Fusion I could open a drawing designed with AutoCAD LT. See in attach 20120725 - DTA. I have checked with a trial license of Fusion and the result comparative is in pdf attached too. There is somebody with an official license of Fusion to open the drawing and show me if the result is ok or not? Thank you
HughesTooling
The commercial license is the same as the trial so what you see is all Fusion is going to read in the DWG. Fusion's sketch environment is nothing like AutoCad so you are not going to get anything other that lines, arcs and splines. You can also import surfaces, solids and meshes but no text, dimensions etc.
Mark
Mark Hughes
Owner, Hughes Tooling
