Online Model Viewer Broken - No Toolbar or Model Shown
tedbradley314
tedbradley314
I've shared my model via:
File > Share File Link > Toggle On
https://a360.co/4e6vTzS
This is what the page at the link looks like (below) even after 5-10 minutes.
When I go back to the share dialog, the toggle has turned itself off.
I believe there are a couple bugs here:
  • Page at link should not display blank/broken state.
  • Share toggle should not turn itself off.
jhackney1972
I suggest you try another Web Browser and also check your graphic settings.  It looks just fine to me.
John Hackney, Retired
tedbradley314
Can you please try this link?
https://a360.co/4hgGgUC
And see video.
I'm using the latest version of Chrome, which has 62% market share of browsers in the US.
(view in My Videos)
jhackney1972
That link does not open nor can I download or open it in Fusion.
Edit: Try going into the Web Database, develop the View there and then use the Share link icon from there.
tedbradley314
Can you explain what you mean by "does not open"? Are you getting a 404 error, or some other error in your browser? Here is what I see on my phone (testing a second browser). Attached.
jhackney1972
It will finally download but the Viewer will only show a white screen like there is no image to view.  As I said, go to the Web Database and generate it first, then share it as I show in the last post.
tedbradley314
The above link is now working.
@jhackney1972 I will try the share link in the web database in the future, thank you for the recommendation.
The two bugs I listed above are needing resolution.
Though the problem resolved itself in the end several hours later, there appears to be an intermediary state that leads to a broken user experience.
