on the new NC Program window, at the bottom of my screen i dont have a ok , or apply button
dhb9mm
dhb9mm
Fusion 360 was working fine for me on Suday. Monday it started wanting me to pick a post processor again. My screen does not show a post, apply, or ok button on the bottom of that screen. The only way I have to close it is the X on the top right corner, so it does not save my setting. There fore I cant post anything. the attached picture is of the whole up and down part of my screen.settings.png
serge.quiblier
Hello @dhb9mm
Are you using a screen resolution less than 710 in vertical?
Apparently on my computer the smallest size acheivable seems to be X 800 Y713.
Can you confirm your display resolution, please?
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
dhb9mm
Is that a windows setting or F360 setting? I will check when I get home.
serge.quiblier
It a windows settings, show the desktop using the right most button, right click on the background, where there is no icon.
You should have an option Display settings, or something specific to the video card, as nVidia config panel.
And you should have in one of the tab a display resolution defined.
I can't add any screen capture, as my Windows 10 installation is running in French.
Serge.Q
cam.autodesk.com
dhb9mm
my display settings were at 1920 x 1080. But everything was scaled to 150% so I took it down to 125% and I can now see the button at the bottom.
