OK Button constantly greyed out - hiding/unhiding any element activates it. Heads-up field also not visible often.
chrisQX8DX
chrisQX8DX
So this issue has been ongoing since a while and the last couple of Fusion updates didn't fix it. Now it's really getting on my nerves. This happens constantly on almost all operations, regardless of the workspace or file i am working on. Extrude, Filet, Offset face, etc. There is no logic to it.
When this happens and i can't click OK because it's greyed out, hiding and unhiding ANY elemnt in the browser will make the OK button active again. There are days when it only happens a couple of times but days like today where in ANY operation the OK button is inactive and i have to hide/unhide before i can OK.
Another issue that's been popping up a lot lately is that i don't get a headsup field to enter values, for extrude and filet for example, i have to type in a value in the dialog panel. When this happens, even if i use the arrows to drag out an extrusion or a filet the heads up field does not appear.
What's going on ? Is this a known bug or something i can fix on my system but this never happenede ever before until a couple months ago and i haven't changed system or components on my computer.
I'm on MacOS Monterey
Intel Macos 15.1.1
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. Whenever needed or whenever i can i will attach a file for troubleshooting. If no file is attached i will always try to explain as clearly as possible and if needed or helpfull provide illustrative screenshots. When i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
eerier_bleach0f
Reported this probably 2 years ago. When this happens I hold the center mouse button down to pan the camera. This makes the "OK" box un-greyed out and clickable.
On M1 Mac.
As for your second issue: I'm assuming their is a textbox field it's just hiding. The placement of the text box is usually pretty dumb and random.
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
chrisQX8DX
hey thx for your reply. yeah i've seen some pretty old threads about this. so is this a mac issue ? i'm on an intel mac with an AMD GPU so it's surprising to hear that it also still happens on a M1. Super annoying bug and a real hog on productivity.
For the heads up field i also thought it might just be in a place wher ei just didn't see it and i agree it's position is really super dumb even when it works i always have to move it around cause it tends to be on top of stuff i need to touch. But when it's not there it's really not there at all, even when i repeatedly click on a gumball arrow which normally should highlight the field.
Intel Macos 15.1.1
