Offset Surface
Offset Surface
leonardo.k
Offset Surface
leonardo.k
Hey guys.
I really don't know what I'm doing wrong here.
For some reason I just needed a offset surface to do some work and just found this, see the videos.
jhackney1972
I do not see anything you are doing wrong.  Try to restart Fusion, if that does not work use the Fusion Service Utility to run the Repair Option.  You will find it under Help, Support and Diagnostics.
John Hackney, Retired
TheCADWhisperer
@leonardo.k
I just verified that it works on my machine.
Just out of curiosity, can you Attach a file that exhibits this behavior?
leonardo.k
@TheCADWhisperer Attached.
@jhackney1972 I just repir Fusion and didn't work at all. I will reinstall.
jhackney1972
I used your file and offset two surfaces without issue.
leonardo.k
Need to reinstall Fusion 3 times to work without any issue.
Thanks a lot guys.
