Offset plane to object doesn't update
brettskaloud
Observer Observer
brettskaloud
Observer
Observer
I created planes based on points in a sketch using the offset plane to object option.  However, when I update the sketch, the planes don't update with the new location of the points.  Is there any way to fix this so the planes will update?
g-andresen
please share the file and tell which planes  sketches and elements you are talking about.
günther
jhackney1972
Take a look at the Screencast.  Notice I have no issue executing what you describe.  Notice if I did anything you did or did not do.  If you cannot replicate the same results, please attach your file and/or a Screencast showing your issue.
John Hackney, Retired
brettskaloud
Observer
Observer
Figured it out.  I was creating planes on a sketch from another model (skeleton).  If I first project the reference points on the sketch, then it updates.
