Offset Dimension numbers cannot be dragged out! [BUG]
Beyondforce
Advisor Advisor
Beyondforce
Hey guys,
Please check this out:
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
rohit.bapat
Hello @Beyondforce
Thank you for posting the bug. We have an item FUS-21754 logged sometime back which talks about the same issue you mentioned.
Thank you,
Rohit Bapat
P.S.
The reason why offset didn't work next time because Offset of Offset is not yet supported in Fusion 360
Rohit Bapat
Product Owner
stevsmar13
Hi @Beyondforce,
I'm having similar fun with offset dimensions:
https://forums.autodesk.com/t5/fusion-360-support/offset-dimension-dislocated-from-sketch/td-p/76471...
Steven Smart, Winnipeg
@rohit.bapat
should this behaviour really be considered as a bug? I have a different opinion.
In the drawing-environment, Fusion 360 dimension-functionality should support everything that is defined in standards: ASME, ISO, DIN (we germans are notoriously fussy about correct dimensioning styles).
But: here we are in the sketch environment and I think it is helpful how the current offset sketch-dimension gives information: source-geometry and direction/value of the offset. So it ist created with just one arrow (shows direction)  and therefore cannot be moved outside. No need to create a sketch-dimension that matches drafting standards - this is the business of the drawings module.
Manfred
