Obstacle geometries are likely blocking the line of sight.
ilayda_ozmerter23
Observer Observer
ilayda_ozmerter23
Observer
Observer
Hi, could someone please tell me why I'm getting this error when I try to generate this.
'Obstacle geometries are likely blocking the line of sight between preserve geometries. Check your study setup and consider using a starting shape.'
I've tried removing the obstacle geometries and this still doesn't fix the error.
Many thanks!
CGBenner
@ilayda_ozmerter23
Welcome to the forums.  I see that no one has offered an answer yet to your question.  Do you still need help with this?  If so, you may want to open a Support case directly.  Good luck!
Chris Benner
yinghq
Observer
Observer
I also ran into this issue today and don't know if there is an answer to this question.
yinghq
Observer
Observer
Bro, after my adjustment, I found that after canceling the initial geometry element setting, this problem has been solved, I hope it can help you.
