Object has wrong dimensions after export to STL (se photo)
mare92_cool
Observer Observer
Message 1 of 10
mare92_cool
Observer
Observer
Hi!
I've been designing an object to 3D print using prusa slicer. In Fusion 360 the object has certain dimensions. But when I print the object it has bigger dimensions (se photo). I've tried to figure out why;
- Units are in mm as intended in fusion
- I did not alter the model in the slicer.
The STL is also i attatchments if that helps! 
Thankful for help!
/Martin
Replies (9)
Message 2 of 10
g-andresen
please share the f3d file
File > export > save as f3d on local drive > attach to post
günther
Message 3 of 10
mare92_cool
Observer
Observer
It is now added as attachment
Message 4 of 10
emare62
The stl is ok, at least in Bambu Studio keeps the original dimension 16.75mm
I had to cut the part to be able to measure it in the slicer, but I think it is a good way to show the dimensions in the slicer
Message 5 of 10
HughesTooling
Are you sure your Vernier is zeroed?
Mark Hughes
Owner, Hughes Tooling
Message 6 of 10
mare92_cool
Observer
Observer
Well this is embarrassing... Turns out you are right!
I even measured the duplo part that this wrench is supposed to fit with this "unzeroed" caliper and designed the whole thing wrong...
And since I didn't do a parametric design I have to do this all over again.
If this doesn't become a meme or turn up on reddit I'd me surprised.
Thanks for the solution. Hope this amuses someone out there.
Message 7 of 10
MRWakefield
Good catch!! This leaves me a bit confused though. Obviously you can zero the caliper at any +ve value but this must have somehow been zeroed against something with a negative size. Or am I going mad?
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 8 of 10
g-andresen
I would also like to have that explained to me.
Günther
Message 9 of 10
HughesTooling
I usually stick with Mitutoyo digital calipers but I have a couple of cheapo Moore and Wright ones and if the battery connection is not good they will sometimes jump to -5mm. Found I needed to bend the spring battery connector a bit and the problem goes away.
Mark Hughes
Message 10 of 10
MRWakefield
Yes, good point about the iffy battery connection I've seen random values come up as well in the past with cheaper or earlier generation digital instruments. It's a shame about M&W, it used to be the go-to if you go back 40 years or more.
Marcus Wakefield
