OBJ import
OBJ import
vladimir_michl
Advisor Advisor
OBJ import
vladimir_michl
Nice move with the centralized Open function in the latest build, much logical now.
Performing an import on an OBJ file (drag-n-drop support would be even better) and immediate deletion of the imported object leaves Fusion canvas graphics in a blank, cropped state.
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
ryan.bales
Autodesk Support
Autodesk Support
I think this has more to do with a few things:
  1. Adaptive grid's
  2. Size of the OBJ
Its likely that with adaptive grid enabled, the size of the obj is forcing the cutoff as the zoom factor appears quite high. You can test this in blank file by zooming out. Eventually it will break the adaptive grid.
It might be a defect with the adaptive grid but its easy to fix. Just switch it to fixed in the Grid settings and then back to adaptive. You might need to zoom back in a ways afterword or beforehand (depending on how far out you've zoomed.
Ryan Bales
Fusion 360 Product Support
