Nvidia GTX
Nvidia GTX
Nvidia GTX
Hey people, how about trying to have a good settings for Nvidia graphics cards - maybe a general one, but good even if you go 10 hours on a project.
Because I`m experiencing sometimes delays and low fps on my Nvidia GTX 880 M
------------------------------------------"about" -----------------------------------------
NVIDIA System Information report created on: 04/16/2017 01:11:26
System name: BIGGUY
[Display]
Operating System: Windows 10 Enterprise, 64-bit
DirectX version: 12.0
GPU processor:  GeForce GTX 880M
Driver version:  381.65
Direct3D API version: 12
Direct3D feature level: 11_0
CUDA Cores:  1536
Core clock:  954 MHz
Memory data rate: 5000 MHz
Memory interface: 256-bit
Memory bandwidth: 160.00 GB/s
Total available graphics memory: 20421 MB
Dedicated video memory: 4096 MB GDDR5
System video memory: 0 MB
Shared system memory: 16325 MB
Video BIOS version: 80.04.F4.00.02
IRQ:   Not used
Bus:   PCI Express x16 Gen3
Device Id:  10DE 1198 157D1043
Part Number:  2053 0002
[Components]
NvGFTrayPluginr.dll  3.4.0.70  NVIDIA GeForce Experience
NvGFTrayPlugin.dll  3.4.0.70  NVIDIA GeForce Experience
nvui.dll  8.17.13.8165  NVIDIA User Experience Driver Component
nvxdplcy.dll  8.17.13.8165  NVIDIA User Experience Driver Component
nvxdbat.dll  8.17.13.8165  NVIDIA User Experience Driver Component
nvxdapix.dll  8.17.13.8165  NVIDIA User Experience Driver Component
NVCPL.DLL  8.17.13.8165  NVIDIA User Experience Driver Component
nvCplUIR.dll  8.1.940.0  NVIDIA Control Panel
nvCplUI.exe  8.1.940.0  NVIDIA Control Panel
nvWSSR.dll  6.14.13.8165  NVIDIA Workstation Server
nvWSS.dll  6.14.13.8165  NVIDIA Workstation Server
nvViTvSR.dll  6.14.13.8165  NVIDIA Video Server
nvViTvS.dll  6.14.13.8165  NVIDIA Video Server
nvDispSR.dll  6.14.13.8165  NVIDIA Display Server
NVMCTRAY.DLL  8.17.13.8165  NVIDIA Media Center Library
nvDispS.dll  6.14.13.8165  NVIDIA Display Server
PhysX  09.17.0329  NVIDIA PhysX
NVCUDA.DLL  6.14.13.8165  NVIDIA CUDA 8.0.0 driver
nvGameSR.dll  6.14.13.8165  NVIDIA 3D Settings Server
nvGameS.dll  6.14.13.8165  NVIDIA 3D Settings Server
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for posting! Smiley Happy
I think you have already installed the latest version graphic driver. we recommend installing the latest version.
Have you enabled the "Limit all effects to provide optimum performance option" on Graphics Diagnostics command from the Help drop down menu?
This article will help.
Please make sure that Fusion 360 recognize your GTX Graphic card.
Additionally, I'm using while turning off all of the effects.
There are options in Fusion 360 in order to improve a performance as far as I know. Smiley Sad
Could you let me know whether it work after setting those options?
I look forward to your reply
Many thanks,
Ahreum.
PhilProcarioJr
@Anonymous
Your performance is going to be almost completely dependent on your model complexity, appearances and GFX options that you have set.
Since you haven't shared the model you could try these things:
You could try the settings @ahreum.ryu mentioned.
Things like modeled threads, errors in your timeline, shadows, ambient occlusion, reflections and anti-aliasing can kill performance.
Another thing to do is to right click on components that are not being worked on and make them unselectable or hide them altogether with the light bulb next to them.
All of these things should increase your performance quite a bit.
Phil Procario Jr.
Owner, Laser & CNC Creations
I have the exact settings (except better performance, which I checked now)
[GPU Information]
GPU Device: NVIDIA GeForce GTX 880M
GPU RAM: 4096 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 1.4.549
GPU Driver Date: 11/30/2016
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Limit effects to optimize performance]
On
But I was thinking maybe a profile in Nvidia panel ... you know what I mean ?
