Not intstalling in windows 10 pro os . regards
confidential_in
confidential_in
Community Visitor
Community Visitor
Fusion software was not insstalling in winddows 10 pro os
jhackney1972
Please attach the autodesk.webdeploy.streamer.log file.  This will help determine the installation issue.
John Hackney, Retired
confidential_in
Community Visitor
Community Visitor
Please tell me about : how to attaching the log file ? ##- Please type your
reply above this line -##
RajkumarIlanchelian
@confidential_in Did the install throw an error while installing? If it did then there is a message that tells you about the log files. Click on it and attach the file you see in there.
If you are not seeing any way to get the logs, then please do two things:
1. Attach an image of the error you are receiving
2. manually collect the logs -
Installation Log files:
For installation or update errors.
  • Windows: C:\Users\(username)\Appdata\Local\Autodesk\autodesk.webdeploy.streamer.log
  • macOS: Macintosh HD>Users>(username)>Library>Logs>autodesk.webdeploy.streamer.log
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
jhackney1972
If you already have the log file simply use the Attachment Section of a reply post to attach the ENTIRE file.  If you need to find it use this web article.
