Not always able to go back to the root of a Project in the data panel
In the newest update of Fusion360 the data panel is slightly adjusted. But I noticed that when your projectfolder name + folder name (inside of the project) combined together are too long you can't go back to the root anymore via the arrows on in top of the data panel. The only way working for me is to get out of the project completely and make my way back into the projects folder structure.
Here 2 images to illustrate:
Only the right arrow lights up when hovering over with your cursor. You can't click the left one. I believe normally there should appear 3 dots in between the two arrows (see bottom picture), which generates a drop down menu of your folder structure. But not in this case.
Different setup just to demonstrate what should happen right?
Goof
