Newly extruded body turning white / semi-transparent after modifying the timeline
nietaki
nietaki
I was re-working the timeline of a small design and ran into a situation where a body would turn white or semi-transparent in a way which I haven't seen before. I'm used to Fusion 360 being fussy when reworking the timeline, so I decided to roll the design almost all the way back and build it afresh.
Turns out, with a design that only has two elements in its timeline: a plane and a sketch on it, I'm still getting the same issue. Any ideas what's happening here?
Here's a screen recording of the problem:
https://youtu.be/0qmbJsFVF1M
I attached the design export.
nietaki
Not a bug, I must have changed a setting in Fusion 360 by accident to only show the wireframes. Here's the solution - changing the visual style back to "shaded with visible edges only" (ctrl+6)
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/All...
I haven't worked with Fusion 360 for long enough to run into all the silly problems yet 🙂
