New update - problems with rendering
Hi Gays,
I have a problem with rendering after fusion360 update.
When I want to create a render of my project it starts but just after few minutes of rendering it stops.
When I open a window from render gallery it shows me a statement
"The specified rendering could not be found"
Please help me if you have any idea what's happened.
masa.minohara
Hi @Anonymous,
Thank you for posting in the forum! Is that happening with any of your designs, or is it specific to one design? If that is design specific issue, would you mind sharing a public link to the design with me so I can test?
Did you perform local or cloud rendering?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Hi Masanobu Minohura
Thanks for your reply.
I don't know is it regular problem or not but I observed the same problem in two of my designs. In both of it I try to use my own light and render time was approximately about 12-20h.
In attached link I had like to created a 3600x3600px render as a local file. And today I had a hope to make it because I started it yesterday morning and it was broken today at 4am today - almost finished file.
https://a360.co/2RRaS3b
Thanks and hope to solve this
Grzegorz Majka
masa.minohara
Hi @Anonymous,
Thank you for sharing your file with me! I downloaded a copy of your design and tried both cloud and local render, and I had no issue.
Could you try the following items to see if they make a difference?
  • Save the design as a new version, and then perform rendering again
  • Download a copy from the web here, upload it to a project, and then perform rendering
Masanobu Minohara
No, it is steel the same problem.
I try both methods which you suggested. - same problem
Please try it with this sets - attached file
masa.minohara
Thank you for your response! I was able to perform cloud rendering using that view without an issue, but I'm still running Local Render. I'll post an update as soon as it's done.
Masanobu Minohara
