Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
New update - new problems with rendering
baddipl
Message 1 of 10
baddipl
Of course the problem with rendeinrg is still not solved and sometimes I still can't render any image cause "RENDER" button doesnt work. Only f360 restart helps.
But nvm...
There are two news bugs.
I can't render anything via cloud because of "Your rendering could not be rendered because an error occurred" so good job.
And second problem
When I am rendering an image locally then I dont see god **** image in my render gallery........................
OHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!
Replies (9)
Message 2 of 10
Are there any news on the rendering problems? My assembly is all messed up as rendered but not in the window
This is after last update
Message 3 of 10
Message 4 of 10
baddipl
Roy, I have also this problem. Rendering locally works fine, but rendering in cloud not and there is a rpoblem that You show on the screens.
Message 5 of 10
Same Bug:  https://forums.autodesk.com/t5/fusion-360-support/june-11-2018-cloud-rendering/td-p/8068761
P.S. I think that a problem is the lack of an issue tracker for bugs
Message 6 of 10
Same problem, cloud renders unusable.
Message 7 of 10
ryan.bales
Autodesk Support
Autodesk Support
Hi all,
I've been tracking this issue and the development team is looking into this right now.
Ryan Bales
Fusion 360 Product Support
Message 8 of 10
ryan.bales
Autodesk Support
Autodesk Support
Hi all!
Please re check cloud rendering. This should be fixed as of 12pm PST. I verified it in my test file and it does appear to be fixed.
Ryan Bales
Message 9 of 10
I tested with 3 files, totally works for me
Message 10 of 10
Thank you!
