New interface, 10 editable file list
jm_info
jm_info
Community Visitor
Community Visitor
I am so stuck with this new interface. Ever since they have changed the project file list. I cannot find my 10 editble file list anymore. Does anybody have any ideas?
dsouzasujay
Hi @jm_info ,
The 10 editable document limit is still available for Fusion for Personal Use. The way you manage those documents has changed a little with the updated interface.
Open the Data Panel, locate the design you want to manage, and use the document status dropdown to switch it between Editable and Read-only. Making a document Read-only frees up one of your 10 editable slots, and it does not delete or remove the design.
If you are not seeing the Editable / Read-only option at all, could you please share a screenshot of what you see in the Data Panel? That will help us guide you based on the interface shown on your side.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
matthewZYM62
I think OP is referring to this list:
