Hi Fusion Team,
I've finally figured out why two newly-built PC's weren't faster at CAM generation than a 2010's pc, and I think it merits an easily-findable help topic sticky.
On both new PC's, F360 defaults to using only the four e-cores which are capped at 3.6Ghz, and are unaffected by the 5Ghz intel turbo boost.
Disabling e-cores in the BIOS has cut tool path generation time by 50-80%.
Generating toolpaths is now spread across 8 p cores running at 4.5Ghz, and some toolpaths will use all eight P-cores pegged at 100%.
It calculated a 1hr long rotary contour path in about 70 seconds.
There have been a few posts on the forum about it, but they never came up until I specifically searched for them.
Anyway, even if it doesn't warrant a help topic, hopefully this post might help someone in the future.
