New Copy with Drawings feature doesn't work
sean
sean
I am very excited about the new feature that will allow drawings to be copied with designs.  This will save a TON of time remaking drawings for design copies.
I am having trouble making it work through.  I keep getting an error message that says "Copy failed.  Forbidden: are you sure you have permission?".  I definitely have permission because this is my design and drawing.  I tested copying the design WITHOUT including the drawing and it copied fine.  So I think that means the problem is definitely with the new feature.  Anyone else having this issue?
HughesTooling
Edit. Sorry see you have a different problem than it not working at all!  You should probably move this post to the support forum. @seth.madore can you move this thread?
I've been told that about 20% of accounts had it enabled yesterday and the rest would be enabled over the next few days.
Mark Hughes
Owner, Hughes Tooling
sean
can do
jainish.jain
Hi Sean,
Thanks for trying out "Copy With Drawings" feature. I am extremely sorry that it didn't work due to "Permission Denied" error. We have fixed that problem in the back-end and you shouldn't see this problem anymore. In case you're not seeing the 'Copy With Drawings' option anymore, it may be due to gradual roll out. If you can share email address used to login with Fusion, I can enable it for you.
Jainish Jain
Jainish Jain
Software Architect - Fusion 360 Data Model
sean
It works now, thanks!
