need to edit post processor
villavicencio_jr
villavicencio_jr
Hello, I was wondering if I can edit post processor so that machine is able to turn off plasma before moving to next cut. It's turning off but it's moving before it turns off all the way. So I think i need a dwell after m5?
jhackney1972
You will probably get better and quicker answers if you post your question on the Fusion 360 Manufacturing Forum.  If you do, you really need to give a hint as to the Post Processor you are using and want to modify.  You failed to mention it in your original question.
John Hackney, Retired
serge.quiblier
Hello @villavicencio_jr
If you either tell us which post you are using, or if you attach the post to your answer we could be able to provide you a snippet of code.
To tell you how to change the post or use a property depending on what is available in the post.
Regards
Serge.Q
Technical Consultant
cam.autodesk.com
serge.quiblier
The new post is there
Serge.Q
cam.autodesk.com
serge.quiblier
Serge.Q
cam.autodesk.com
