Need to create a raised vertical rib on the inside of a cylinder.
databank
databank
Need to create a raised vertical rib on the inside of a cylinder. The vertical rib would be the length of the cylinder and only 1 mm high.   I would then pattern it to go around the 4 quarters.  Hey I am a newb so hope you don't mind the question.
jhackney1972
Here is one way to do what you asked for.  Model is attached.
John Hackney, Retired
databank
Wow, you are the man!   That is exactly what I wanted.  Thanks for taking the time, I appreciate you.  Merry Christmas and Happy Holidays.
