NEED HELP WITH PRESS PULL/MODIFYING PART
randyt88rsb
randyt88rsb
I have a part, not super complicated but i want to make the thickness of it from .75 down to .625
It has chamfers and fillets so when i try to press pull it wont take it, any help is appreciated, screenshot of part.RB1.png
jeff_strater
@randyt88rsb - can you share the design here?  (and, also, a bit more detail about what dimension you want to change from .75 to .625).  In general, I would stay away from Press/Pull for something like this.  It defaults to "automatic" mode, which can be confusing.  Is this a parametric design?  If so, it should be easy to change the thickness,  If not (if it is imported, for instance), there may be other ways to achieve the desired result, but we can only help if we have the design itself.
Jeff Strater
Engineering Director
randyt88rsb
Yes sir here you go.
jeff_strater
thank you.  The process here is to just edit the initial Extrude to be a different distance.  Hopefully, this is what you are after.  There are a few warnings in this design that you should try to fix.
Jeff Strater
