Need help with creating thickness
job.hermes
job.hermes
Hi everyone.
Im pretty new to Fusion360 and I cant seem to figure out how to give slightly complex models thickness of 2mm.
I'm a toy modeler with a animation/ games background. meaning I am more of a Organic zbrush / maya artist.
I modeled the surface by importing a mesh from zbrush into fusion and retopologized it with the surface face tool. 
I hope you can help me out, because I will have to create a lot more models like this in the future and I can't seem to figure out a stable workflow.
Thanks in advance!
P-BvanWyk
Good day @job.hermes,
I believe the issue is due to the mesh overlapping when you use shell or offset face.
I had to sitch the mesh to get a sold -> duplicate the solid -> scale it (and orientate) -> Then combine (Cut)
I would recommend that you look at the T-Spline sculpting inside of F360 for your sculpting needs.
I found it works better downstream with F360.
Please click on Accept Solution to help other community members solve their issues.
Also, consider giving a Like to the comments that you feel added value.
Kind regards,
Pieter-Ben van Wyk
