Need help setting origin
cjversatile
cjversatile
I completed this design component but somehow managed to to screw up the origin and I cant seem to fix it.  It's sitting at an angle and below the grid.  Help!
https://a360.co/39ZoLFD
TheCADWhisperer
Right click on your View Cube and select Reset Front.
I immediately notice other issues with your technique.
1. First sketch is not fully defined - this is a major issue going forward.
Duplicate dimensions - unnecessary.
Missing Tangent constraints between lines and arcs. (Use Slot and avoid this issue.)
Did you really intend for the center-to-center distance to be 67.00345367?
I saw multiple other issues going through your Timeline...
See Attached file...
cjversatile
Thank you for your help and comments.  I am still relatively new so this is very helpful.  I didnt really intend on anything other than successfully creating the shape but it was more luck than following best practices.   I appreciate it again.
