Need help building this surface
thekenji412
thekenji412
Hello yall
I need help trying to build this surface, any idea how to build it? If I try to loft it and include the rail, it intersects itself. I dont understand why its happening like this but i am quite confused.
g-andresen
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
thekenji412
Does exporting it also exports design history?
jhackney1972
If the model has a Timeline, Capture Design History is on, yes, the Export will export the design history.  If the information is sensitive, remove all components and bodies from the model not required for the question, then export and attach.
John Hackney, Retired
thekenji412
attached below is the file thanks mate
TrippyLighting
There is no design history in the file you attached. I assume you imported rather questionable geometry and then continued to work with it.
Honestly, I would start from scratch completely!
thekenji412
how would you build that area with a tight surface curve?
