Need a point in the right direction for some education
mikep93
Message 1 of 8
mikep93
I am new to Fusion 360.  I am trying to help my son who is a welder with a sign project he has.  Specifically I am looking for a good tutorial on how to add a svg to a sketch of a circle/square/rectangle so he can do a negative cut out on a plasma table.  I don't need instructions for cutting with Fusion 360.  I need instructions for adding the svg to a sketch with geometry already in the sketch and saving that as a dxf.  I have been hitting youtube pretty hard but cannot quite connect the dots in the tutorials I am finding.  A push in the right direction would be very much appreciated!!
Thank you!!
Accepted solutions (3)
Replies (7)
Message 2 of 8
seth.madore
Here you go, hope this helps 🙂    (there's no audio, just a walkthrough on the steps needed)
Seth Madore
Message 3 of 8
TheCADWhisperer
@mikep93
Attach your files here if you still can't figure it out.
One of the experts here will demonstrate using your actual geometry.
Message 4 of 8
g-andresen
SVG  are normally fixed after import (green). To move or edit them later, you must mark them with the window selection and unfix them.  > lock symbol
günther
Message 5 of 8
TrippyLighting
günther
I would not even do that. I'd rather create geometry and move that, than mess with a dreaded SVG sketch.
Message 6 of 8
mikep93
Thanks!!  That got me to exactly where I need to be.
Much appreciated!!
Mike
Message 7 of 8
mikep93
I think I got things sorted out.  Really appreciate the reply!!
Mike
Message 8 of 8
mikep93
Thanks for the advice.  That helped me get my project sorted out.
Mike
