NC code error "does not contain any operators"
JGilligA43QL
Observer Observer
JGilligA43QL
Observer
Observer
I'm trying to get fusion 360 to communicate with the companies CNC machine. When I try and get the NC file I get an error message that says " does not contain operators"  I have completed the path and ran a simulation that passes but I simply cant get it to create a NC file for me to use with the CNC machine.
jhackney1972
Can you attach your model containing this problem.  Not much to go on without it.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
