Named views store slicing
sboeser
sboeser
is there a way to create a named view that also stores which slices (analysis slices or sketch slices) I have activated? If I want to see a slice from a particular view, this always seems to be a two-step operation of (a) slice and (b) choose view.
Sebastian
Phil.E
Usually I activate the view first, then activate the Section Analysis, but it sounds like you have that part figured out.
The answer is no for section views. Those are viewable from any viable angle and are not tied to camera angle.
The answer for sketch is similar. You must first edit the sketch, then activate the sliced view, as you have found.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
