Multiple copies of a component, which each it's own parameters
JonasVorwerk
Observer Observer
JonasVorwerk
Observer
Observer
For a project I would like to create multiple copies of a component in a rectangular array.
Each copy of the component has at least one parameter that has to be different than the other components.
Is it possible to create components with it's own set of parameters?
g-andresen
it depends on what you want to change.
Try it this way:
1. create a pattern
2. copy and paste new such components that are to be individual.
3. suppress the origins
günther
JonasVorwerk
Observer
Observer
Thanks for the tip: suppers origins, didn't know this.
Altho this doesn't answer the question fully.
Working with components is great, but components should have the ability to slightly change.
For example, 200 flag poles in a rectangular pattern, all in the same construction / pole angle only the angle of the actual flag must be slightly different. How would this be possible?
The parameters seem to be global, it is possible to create local parameters per component?
mikLamming
was this capability ever added?
