Moving section view to face moves it to random location
FrodoLoggins
Advisor Advisor
FrodoLoggins
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
jhackney1972
Your Section Analysis is being placed in a seemingly random location because you are selecting the chamfer face, which is not square to the Section, to position the location.  Go back and look at your recording and you will see the issue.
John Hackney, Retired
FrodoLoggins
If that is the case then this is inconsistent behavior. Normally selecting that chamfer face would move the section to either one of the below dotted lines. I say "either" because the behavior is inconsistent.
jhackney1972
No, selecting the chamfer face will not select either one of your dashed lines as a location.  If you want one of them, then select the vertex at the end of either side of the chamfer.
FrodoLoggins
You're certainly free to believe that but my experience says otherwise.
