Moving multiple components stops working after a certain time
linobss
linobss
I often need to move more components together.
I normally choose them from the tree, holding Ctrl key while clicking them, to select/unselect the items.
Then, with the command Move, I can normally move them.
Nevertheless, after a certain time, it stops working. After giving the command Move, all the previus selected components become unselected except one. So I'm able to move just that one. Therefore I should select and move all the components one by one.
The strange thing is that if I exit and restart Fusion 360, it returns normal, I can regulary select and move my multiple components, for a certain time, until it stops again funcionning.
I can't figure out if it depends on my behaviour, because it seems it happens randomly.
Thank you for any support
A. Basso
tickranch
I'm seeing the same behavior. v2.0.8609
linobss
Hello thickranch,
I had the problem solved by Autodesk support
The reason was that I used to select Translate
This option deletes all the selection except one
Using the option Free move the problem doesn tot happen.
Maybe you can watch the video that Sriniwasa from Autodesk support hat sent
to me
Here below the link
https://knowledge.autodesk.com/community/screencast/13b186db-7f12-4dc0-a457-90f02966c051
Best regards,
Lino
tickranch
Thanks Lino; I’ll check that out!
Charlie
