Moving / Copying drawing views between sheets
Is this possible? any help would be great.
jhackney1972
No, the moving of drawing views is not possible in Fusion 360 at this time.
John Hackney, Retired
Will this feature be available in the near future?
jhackney1972
I cannot speak for the developers at Autodesk as I am a Forum volunteer, just a user like yourself.  You can look at the Fusion 360 Roadmap Update 2020 website and see what they are planning.
Garret_H
There is a workaround, but it's kind of gross.
Perform a "save-as" and create a new copy of your drawing. Then you can delete what you don't want in each drawing.
Depending on your drawing number/sheet scheme this may cause you some headaches of its own, but hopefully less than trying to redo a bunch of work that you already put in.
FacebookGroupMember
When it comes to drawings, best thing I ever did was create a template. My .02
