I use dimension and constraints quite a lot keep things aligned when moving other stuff. I have never noticed a problem until today where it all fell apart.
To test,
-> new design
->new sketch
->draw a 4 sided random shape with 4 lines.
->use the perpendicular constraint on 3 of the corners to turn it into a rectangle.
-> grab just one of the lines and M to move. rotate it in the plane of the sketch
Expected: all 4 lines move/rotate together to honour the constraints and maintain the rectangle.
Actual: at least 1 of the perpendicular constraints are broken (they just disappear) and the shape becomes irregular.
Is this a bug or am I going mad?
before move/rotate
https://www.dropbox.com/s/ywqo26c9gvyy834/Screenshot%202021-02-04%2018.44.31.png?dl=0
after rotate
https://www.dropbox.com/s/b8dev5g790cz9dw/Screenshot%202021-02-04%2018.45.25.png?dl=0
if it matters...
2.0.9719
Active Plan: Fusion 360, Personal
Windows 10 (18363)
